It is currently Sat Jun 27, 2026 1:31 pm
 Post subject: S-10 brake line
PostPosted: Wed Sep 18, 2002 12:34 pm
I'm putting an s-10 rearend in my '79. How do you connect the metric LUV hard brake line to the standard s-10 brake hose?
PostPosted: Wed Sep 18, 2002 3:05 pm
the best way i know is to use the luv hose and hard line.cut the ends of the luv hard line off put on standard fittings and reflare the ends. you just need small tubing cuter and flare tool. you can do that at the backing plates,or use the luv hose and juction block .then just do the same as above at the block. :twisted:
PostPosted: Thu Sep 19, 2002 5:01 am
hey they should both match up.
I vagley remember doing mine and I had no problems with any hoses or hard lines matching up.
before you go cutting on stuff see what will match up.
 Post subject: s-10 brake line
PostPosted: Fri Sep 20, 2002 11:20 am
Thanks for the responses. What I did was use the LUV hard lines across the rear end and put on the s-10 fittings at the wheel cylinders. John
Users browsing this forum: Bing [Bot], Google [Bot] and 58 guests
