It is currently Sun Jun 07, 2026 7:18 pm
 Post subject: Stabilizer bar bushings
PostPosted: Tue Apr 15, 2014 6:46 pm
I have a Diesel, 4X4 1982 LUV and can't find replacements for the bushings & washers that go between the stabilizer bar and the lower control arms. NAPA, O'Reily's, and Autozone said they can't get them and it didn't look like Rock Auto had them either. Does anybody know another source?
PostPosted: Tue Apr 15, 2014 10:48 pm
Just to be clear, by "stabilizer bar" do you mean the anti-sway bar (which Isuzu calls a stabilizer bar)? Or do you mean the strut rod that goes at an angle between the frame and the LCA on each side?
The sway bar end links can be replaced with a universal kit from Energy Suspension, Autozone generally has a selection, just get a kit the same length as stock, or get one a bit longer, cut the spacer tube to the correct length, use new bolts if the supplied ones can't be cut to fit.
If you mean the strut rod then you aren't asking for the right part by requesting a stabilizer bar bushing.
PostPosted: Wed Apr 16, 2014 6:32 am
You're a member at IsuzuPup.com. Just contact JLEMOND over there. He should have the factory parts you need. I recently replaced all the front-end bushings and ball joints in mine, and got them from Jerry.
PostPosted: Wed Apr 16, 2014 4:36 pm
As always you guys are the best Thank You!
