It is currently Sun Jun 07, 2026 2:27 am
PostPosted: Tue Apr 15, 2014 10:41 am
Been on the 'home stretch' of getting this truck on the road for a brutally long time. Each part takes about a week to come in and when you couple that with multiple wrong orders, things can get frustrating. Any help would be appreciated.
Below is a picture of the original clutch. The two that I have ordered so far are too big! Anyone have any ideas?
P.S. I still am not positive what series I have...
https://mail.google.com/mail/u/0/?ui=2& ... w1243-h520
PostPosted: Tue Apr 15, 2014 1:12 pm
Your picture shows an 8" clutch, '79 4x4s & all '76- '82 2wds had the 8" clutch, order one of those & you will be fine. The 4x4s from '80 on and the 2wds from '83 on had the 8.5" clutch, which uses a different flywheel. Your truck must have been built to '79 specs if the 8.5" clutch won't bolt up, check the build date on the door pillar.
PostPosted: Fri May 02, 2014 8:20 pm
So it actually turned out to be a 7 7/8" kit... Which is in there and working beautifully. The odd thing is, the guy at oreillys said it was listed for a 2wd model. Same thing for my calipers... Computer error or someone swapped out 2wd parts...? Thanks for the input!
