It is currently Wed Jul 01, 2026 1:20 am
 Post subject: Dash lites
PostPosted: Tue Nov 18, 2003 11:50 pm
What kind of bulb and how do you change 'em that illuminate the names of the switches along the bottom of the dash. I only have one working now. I found nothing in my manuals.
PostPosted: Wed Nov 19, 2003 6:35 am
Im not sure witch one you are talking about.
there is a panel with 2 screws above the heater controls that has lights in it.
on the panel with the ignition switch on some models it has just one illuminated....yours might be that model. I don't think all of it is illuminated.
03Cobra
PostPosted: Wed Nov 19, 2003 10:43 am
You can replace the dash bulbs with a #198 wedge base. Its brighter than the stock (#158, I think?) but is same size and base. One of the most common automotive bulbs.
PostPosted: Thu Nov 20, 2003 1:30 pm
Since were on the topic of dashlights, i got a problem too. If i just turn on my parking lights, my dashlights work, but if i turn on my headlights, my dashlights quit. Could it be that i just need a new switch?
:snipersmile: :2gunfire:
PostPosted: Thu Nov 20, 2003 5:09 pm
Yeah, either that or you need to get under the dash and make sure that the wire for the dash is actually connected to the "fully out" position where your headlights are on.
PostPosted: Thu Nov 20, 2003 5:11 pm
i wasnt sure if the switch was bad because another person had problems like mine and his switch was bad.
