It is currently Fri Mar 29, 2024 5:03 am
PostPosted: Sun Mar 09, 2014 9:28 pm
Hi I am looking for a little help keeping my 79 luv 1.8 running. Here is my story...The motor is all stock and recently it was running just fine and was getting ready for cosmetic repairs. I started the Luv and it stalled. I thought it was just cold. I could keep it running if i feathered the pedal. It refused to stay running. I have tried several steps but same results. Here is what I have tried. Fresh fuel, new filter, new pump, different power source to fuel pump, I found a Weber carb locally thinking something in the carb failed or just sticking. Same symptoms every step I tried.I started thinking vacuum related stuff. checked routing, changed loose hoses, and noticed there was no vacuum to or from distributor advance and none at base of carb. So I am thinking smog pump., because I cant find any vacuum pressure anywhere. Any suggestions where to look nest? Thanks
