 Post subject: flywheel
PostPosted: Fri Dec 27, 2013 5:04 pm
i would like to buy a new one.can i get one anyplace.i just got one ordered on ebay to find out that it was a fake posting.
1980 luv motor.2wd trans
 Post subject: Re: flywheel
PostPosted: Fri Dec 27, 2013 5:55 pm
Try rockauto.com they have a lot of luv stuff. I have a 4wd flywheel thst uses a bigger clutch in the garage
PostPosted: Fri Dec 27, 2013 5:58 pm
I have not seen a new one listed by any parts supplier in several years. They do list the G200/1.9L flywheel (which will fit the G180 & also allow the use of the larger 8-1/2" clutch used in 4wds & 2.3L trucks), however they all list the wrong flywheel (including rockauto.com), they list an 8-bolt flywheel that fits the 4Z-series engines, not the 6-bolt the G-series engines require.
Your best bet would probably be a used one from car-part.com, whether for a 1.8 or a 1.9, then have it resurfaced. I did have a source for the 6-bolt 1.9 flywheels, both new & used, I will see if they are still available if you wish.
Edit: to be clear '79 G180 4wds still used the 8" clutch & matching flywheel, same as 2wds. '80-on 4wds and all later G200s, 2wd or 4wd, used a 8-1/2" clutch & matching flywheel.
PostPosted: Mon Dec 30, 2013 1:15 pm
yep could not find a new one.but i did find a good used one.
thanks
