It is currently Sun Jun 07, 2026 3:38 pm
 Post subject: TAR FILLED FUEL TANK
PostPosted: Sat Dec 14, 2013 1:31 pm
i have an issue with my tank being full of tar from sitting about 20 years without being drained. i put new points plugs wires and rebuilt the carb and temp rigged the factory electric pump under the hood pulling from a gas can. runs like a top but engine smokes assuming from sitting and rings probably being stuck. it got better the more is ran so hopefully itll fix itself. i added half a gallon of alcohol and about a gallon and a half of gas to the tank hook the pump back up and wouldnt pull fuel. i dipped the tank and found it full of runny tar. i assume it was probably hard until i put the alcohol in it to sit for a few days and now it is runny.
so my question is does anyone have an oldschool remedy to this other than stripping and recoating the tank? i also needed to know if it has a sock strainer attached to the sending unit as im sure it is no good either and were to buy one at. i checked local parts stores and noone has one listed as applicable part.
thanks for the help in advance
Jordan
 Post subject: Re: TAR FILLED FUEL TANK
PostPosted: Mon Dec 16, 2013 7:23 am
Take the tank out.Pull out the sending unit.Fill it with diesel fuel or carb cleaner and let it soak.
PostPosted: Mon Dec 16, 2013 10:44 am
Let it soak in mineral spirits.
PostPosted: Mon Dec 16, 2013 10:52 am
Take it to the radiator shop...
Users browsing this forum: Bing [Bot] and 21 guests
