It is currently Mon Jun 08, 2026 3:58 am
 Post subject: 3/4 head gasket issue
PostPosted: Wed Dec 11, 2013 9:49 am
I have had some issue with the head gasket losing the seal between cylinders 3 and 4. I have also purchased some parts motors and they had the same issue. The last time I rebuilt my 180 I bought the best head studs I could from ARP and resurfaced the head and deck. I got about 20,000 before the head gasket failed. Looks to me like a heat issue almost like the coolant flow is not enough to carry the heat away in the back. Has anyone else seen/solved this problem?
PostPosted: Wed Dec 11, 2013 10:48 am
I think people usually have problems between 2/3 where the gap is narrowest. I had an issue with one head i had blowing bwtween 2/3, had a spare machined and it lasted quite a while until i got bored of the 1.8. Maybe check the water jackets for a clog or look for a kinked/crushed coolant line, not sure what else could be a problem in the back of the block
PostPosted: Sat Dec 14, 2013 8:39 am
Be sure to re torque head bolts after several thousand miles. And definitely after any over heating.
