It is currently Sun Jun 07, 2026 1:21 pm
PostPosted: Thu Sep 26, 2013 4:24 pm
:?: Took Clutch out of 72 Luv 2wd, can't remember which way the Clutch Disc is supposed to be facing, I know "Just Dumb" :roll:
PostPosted: Thu Sep 26, 2013 5:09 pm
Flat side to the flywheel, raised side to the pressure plate.
PostPosted: Wed Oct 02, 2013 4:44 pm
Thank You! I also tried to put the disc on the transmission, will only move properly one direction and your answer fits the profile. Thanks again! :ebiggrin
