It is currently Sun Jun 07, 2026 2:45 pm
PostPosted: Mon Jun 03, 2013 9:49 pm
Hey so I'm having an issue with my Luv.
I can start it, but when I push the clutch pedal down all the way the starter starts grinding.
So pretty much when the truck already running, the starter is still wanting to start causing the awful grinding..
I was curious if anyone might have any idea to what it might be to cause this?
As well I can start my Luv by turning it over the the accessory side, I bought a new key switch assemble thinking that may be the problem but I was wrong...
Any Ideas on this?
Please help, thank you.
PostPosted: Tue Jun 04, 2013 5:58 am
New starter needed.The starter solenoid gets activated which engages an arm to push the starter drive to the flywheel engaging the teeth then the electric motor turns the engine over. The arm is sticking.
Users browsing this forum: Bing [Bot] and 27 guests
