It is currently Tue May 26, 2026 10:53 am
 Post subject: Some brake help
PostPosted: Thu Apr 11, 2013 9:52 pm
I just finished converting my 79 2wd to 4wd. Bleeding out the brakes did the rear and got all the air out. I could not get any fluid from the front calipers. I replace the master cylinder, still no fluid. Went and disconnected line by line only a trickle at the rubber hoses. All of the other LUV's I've done the calipers shoot out powerfully at least 4 feet. Any Ideas?
 Post subject: Re: Some brake help
PostPosted: Thu Apr 11, 2013 10:16 pm
Start at the master...crack a line and see if it squirts. if yes, go to the next junction and crack it. Go on down the line towards the wheel until you find one that doesn't squirt.
Many times the rubber hoses degrade on the inside and you won't suspect it because the outside looks great.
PostPosted: Fri Apr 12, 2013 6:54 am
Also double check for kinks.Calipers also might be full of crap.Replace the bleeders too.
PostPosted: Fri Apr 12, 2013 1:57 pm
Thank you. I will put new hoses on it too.
PostPosted: Fri Apr 19, 2013 11:21 pm
I found out the calipers had some sludge blocking the bleeder screws, Also replaced rubber hoses. Problem solved YAY!
Users browsing this forum: Google [Bot] and 66 guests
