It is currently Tue May 26, 2026 5:54 pm
PostPosted: Thu Mar 21, 2013 9:27 pm
OK I have replaced the condenser, the coil,points,ballast resistor, fuses and the fuel pump.I had it running this afternoon after I put the new condenser in. Now it stumbles under load.Fuel filters are brand new.The plugs are clean and all are firing.I set the points up correctly and they are not pitting.I am thinking that maybe the new coil is bad? Monday I will put the old coil back in and see if it makes a difference. Any other ideas?
PostPosted: Fri Mar 22, 2013 12:34 pm
Not enough points gap? isn't it 17 thousandths?
Users browsing this forum: Google [Bot] and 73 guests
