PostPosted: Mon Feb 25, 2013 7:27 pm
Hey
Does anybody know if you can get new gaskets for the tail lights or if not any thoughts
PostPosted: Tue Feb 26, 2013 12:54 pm
I haven't seen any sources for them ever. I did at one point make a template to cut my own out of rubber gasket material. It worked, sort of.
PostPosted: Tue Feb 26, 2013 1:50 pm
I've been meaning to use some sort of round plumbing packing or gasket that comes on a roll.
I think if you chose the right diameter it would be a simple job to lay it into the slot that the gasket sat in.
Put the seam at the bottom.
PostPosted: Tue Feb 26, 2013 7:31 pm
hey thanks for the ideals
I used some weatherstripping for a canopy and cut it strips 3/16 wide and put the sticky side to the housing side and installed the lens and it looks as if it will work as good as the OEM gasket.
