It is currently Sat Mar 21, 2026 4:45 pm
 Post subject: need help with a leak.
PostPosted: Thu Feb 21, 2013 11:19 pm
passanger side heater air vent leaks. i took off fender and inside where the black heater air vent hose connects to right under the window and still cant see where the leak is..I think its from the body welds but can't really see..I know what is the right way to fix it but is their some kind of seal i can run where ever the leak is? just need some ideas thanks
if you take off the cow it is the left side nothing else can be removed...
...........Make Luv..........
PostPosted: Fri Feb 22, 2013 11:27 am
Most likely your windshield wiper arms are leaking. Do a search here, there is good luck using a spark plug boot over the shaft to seal it.
PostPosted: Fri Feb 22, 2013 1:10 pm
I wrote up the wiper shaft fix long ago, but it doesn't seem to show up in searches well. Here is a link and I'm going to resurrect the thread to add some search bait.
viewtopic.php?f=5&t=849
PostPosted: Sat Feb 23, 2013 12:12 am
Thanks guys will check that out...
