It is currently Sun Jun 07, 2026 4:39 pm
PostPosted: Sat Dec 01, 2012 10:29 pm
Help to bypass the fuel pump please any diagram will help a lot
Im no experience mechanic please, should be diagram 101
Thanks
PostPosted: Sun Dec 02, 2012 1:40 am
Thanks
When I got my Luv. I wire off the postive lead from the coil, was run straight to the fuel pump. Perhaps someone with more knowledge on wiring can give you another option as well.
PostPosted: Sat Feb 02, 2013 5:05 am
The way I did it after much cussing was to run a new wire from the fuel pump up to rite after the fuel relay bx by the connector.
PostPosted: Sat Feb 02, 2013 5:07 am
That way the fuel pump still run like it posed to.
