It is currently Sun Jun 07, 2026 7:12 pm
PostPosted: Mon Jan 21, 2013 9:17 pm
Guys...one of the reservoir on the master cylinder keeps getting low.I can't find any leaks.Which system is the rear reservoir connected to? Front or rear? This will help me narrow it down..thanks.
PostPosted: Mon Jan 21, 2013 10:08 pm
Probably leaking into the booster...
PostPosted: Tue Jan 22, 2013 12:05 am
New master cylinder.And it is not leaking down the firewall.At least whenever I have seen it leak into a booster it leaks down the firewall in the cab.
PostPosted: Tue Jan 22, 2013 12:08 am
Rear.
PostPosted: Wed Jan 23, 2013 10:27 am
Thanks guys!
PostPosted: Thu Jan 31, 2013 7:45 pm
Yeah rear reservoir means rear wheels, just follow the lines. It is possible you still have/had air in the lines and it is just slowly working up towards the master cylinder and escaping. More likely you have a bad wheel cylinder though.
PostPosted: Thu Jan 31, 2013 8:09 pm
I was thinking the same thing.It is -40 degrees here right now so...I think I will let it get a bit warmer til I get a good look at it!
Users browsing this forum: Bing [Bot] and 43 guests
