It is currently Sun Jun 07, 2026 8:22 pm
PostPosted: Wed Jan 16, 2013 12:43 am
If there is no inner lip on a 1980 LUV to C-clamp to, how do you secure a topper? Drill holes and screw it down?!? The flush edges have me stumped. And I'm not drilling into my bed. So how is this supposed to work? Can it be done with out modifying the bed, do you have to weld on latch plates?
PostPosted: Wed Jan 16, 2013 7:29 am
i could see it done by having it attach on the outside of the bed thru the 6 tiedown loops with a latch or a thread tightened anchor, not sure how else you could without drilling holes
PostPosted: Wed Jan 16, 2013 7:34 am
I hate to say it but in the old days we drilled holes through the topper into the bed rails. My shell was held on by 4 bolts. Back then they were just mini trucks. 8)
PostPosted: Wed Jan 16, 2013 8:50 am
^ This, no way to mount it without drilling holes
PostPosted: Wed Jan 16, 2013 11:26 am
yeah, they were just trucks and here I had to go and find a mint time capsule... oh well... thanks for the info!
PostPosted: Wed Jan 16, 2013 12:57 pm
I actually saw this done on a LUV awhile back.
Brackets attached to the topper then bolted to the tie-downs.
Looked like crap but worked.
The topper I had on my 79 was drilled and bolted.
PostPosted: Wed Jan 16, 2013 5:13 pm
i was picturing it like this
if you used the hooks you see used up in rafters you could find a nut that would go on it :lol:
or maybe bend and thread a few toedown hooks
