It is currently Sun Jun 07, 2026 8:20 pm
 Post subject: radio fuse
PostPosted: Thu Dec 06, 2012 9:32 am
Where is the radio fuse located ?
Ive scanned under the dash and found zip.
The engine compartment near the drivers firewall has a bank of 15 and 20 amp fuses,but none for radio.
This is for a 81 isuzu pup. Im hoping the luvs will be similar.
 Post subject: Re: radio fuse
PostPosted: Thu Dec 06, 2012 12:52 pm
Diagram shows--#6 fuse (15A) feeds the radio as well as some other accessories.
PostPosted: Thu Dec 06, 2012 1:08 pm
This is a diagram belonging to Series 4 trucks, but it's principally the same through Series 11, on the LUV's at least.
As they seem to have done with many upgrades and options, Isuzu opted to keep it simple and splice things into an existing circuit, rather than dedicate new wires.
In the case of the radio, the windshield wiper motor circuit was their choice.
Also connected to this circuit are the cigarette lighter and the windshield washer tank motor.
All of these lead to the same 15a fuse located in the fuse box. Ser 11 had a smaller box than Ser 4, so don't trust the above diagram to locate the correct fuse.
If your wipers work and your radio doesn't, the problem is between the splice and the radio.
PostPosted: Thu Dec 06, 2012 7:17 pm
I misread a 15 amp fuse.I think i was looking for the word "radio" not what was on the plastic lid;Horn Cigar.
It was located on the drivers side near the firewall mentioned below.
Thanks for your help though.
Users browsing this forum: No registered users and 50 guests
