It is currently Sun Jun 07, 2026 8:20 pm
 Post subject: weber idle creep?
PostPosted: Tue Nov 27, 2012 10:15 pm
have been running m 32/36 weber for quite a while now
but latel i have noticed it will randomly not drop down to idle when i let off the gas or hit the clutch. sometimes it stays around 2k rpm and occasionally it will creep up to 2500+, tapping the gas like you would to kick the choke off doesnt change it.
im trying to figure out if it is something sticking open in the carb or if i need to get a new throttle cable, i notice it happening more during longer drives but that may just be because im sitting there longer.
 Post subject: Re: weber idle creep?
PostPosted: Wed Nov 28, 2012 8:11 pm
Try Seafoam in your fuel.Cleans your fuel system out.Try carb spray too...but but the good stuff.
PostPosted: Sat Dec 01, 2012 4:58 pm
I had the same problem. The throttle linkage was sticking. I sprayed WD-40 around the throttle linkage and that freed up the linkage.
76 LUV
PostPosted: Sat Dec 01, 2012 6:40 pm
thanks i will check it out tonight if the rain stops
man i wish i would have held on to that impulse efi intake :oops:
