It is currently Sun Jun 07, 2026 4:13 pm
 Post subject: Water pump trouble
PostPosted: Thu Nov 15, 2012 2:58 pm
Ok so I'm having trouble keeping my water pump on my 72 from leeking and getting loose.. I changed the the bolts I installed it with and without gasket sealant and tread lock. I don't kno what to do any more I kno for a fact that the tread on the block is good cause I tighten the bolt by its self and tightens up fine... Can anybody help ?
 Post subject: Re: Water pump trouble
PostPosted: Thu Nov 15, 2012 7:41 pm
Why did you post this again? You were getting suggestions on your first post.
