It is currently Sun Jun 07, 2026 11:21 pm
 Post subject: Alternator swap...
PostPosted: Tue Oct 30, 2012 3:05 pm
1979 LUV 2WD short bed base model; 1.8 L w/3 speed auto... The voltage regulator is giving me pain... Want to swap it out with an alternator with an internal regulator. Is it possible to use the Chevy one wire? Or is there something easier?
... Good, you've located the problem; step 2 is washing it off.
 Post subject: Re: Alternator swap...
PostPosted: Tue Oct 30, 2012 9:08 pm
You can use the one wire chevy alternator. Do a search, info is here.
PostPosted: Fri Nov 02, 2012 8:55 am
Can put the Alt. in with no problem... I just need to know what to do with the 5 wires coming out of the regulator... I can't find any wiring diagrams online for the 1979 LUV. Everything is original and clean, just don't want to fry anything... Any suggestions?
PostPosted: Fri Nov 02, 2012 9:28 am
factory wiring diagram http://www.luvtruck.com/PDF/Series9&10.pdf
PostPosted: Fri Nov 02, 2012 9:30 am
Sweet... Thanks bub. I'm sure this will come in handy.
