It is currently Sun Jun 07, 2026 1:22 pm
 Post subject: WINTER TRIVIALS
PostPosted: Sun Oct 19, 2003 8:38 pm
Hey guys. It's starting to get cold in the mornings now and I'm having a problem. My carb is beginning to freeze up on my way to work in the morning because of the cold air being sucked in so fast, and that really sux. It means I gotta stop on the side of the road and turn of the engine and sit for a couple of minutes while I wait for it to thaw. I found out that I need a exhaust heat sheild to put on, and hook up to my air cleaner housing. And nobody has any......have any of you guys seen anything like this for the LUV?
PostPosted: Sun Oct 19, 2003 9:43 pm
do you mean a tube thingy that comes from the exsaust up to the air filter housing? If so they arent that hard to set up i had to do on my f-150 to pass emmisions. Another thing you might look into is if you choke is running right and see if you can get something called a thermostatic valve for the air cleaner.
PostPosted: Mon Oct 20, 2003 12:17 am
sabin, I'm assuming you're running the stock 4 banger... that heat shield is supposed to be on there already unless someone ripped it out. Heres a quick fix you can look into. Go to your local junk yard, rip a decent looking heat shield out of a trooper or pup with a 4 cyl engine in it. It might not be so easy to find one in perfect shape so I wouldn't be too picky. The heat shield will have an outlet at the top for a hose to hook up to. Then go to NAPA or something and pick up a carburateor pre-heater hose. The hose is usually just a simple foil hose that'll go from that heat shield up to your air cleaner. That'll take care of your problem and it shouldn't cost you much at all. Hope it helps.
PostPosted: Mon Oct 20, 2003 8:54 am
I have two of them . There not much use down here in Texas. I could see that ya might need it in the northpole!! If you would like, i could send you one. You just pay the shipping. Let me know.
PostPosted: Mon Oct 20, 2003 9:52 pm
Hey thanks for the input guys. Somebody had ripped the original sheild off. They had some weird setup on the engine that didn't work very well. I put a proper carb on a few months ago and...now it's freezing up. So yea John that would be great if you could send me up one. I would really appreciate it.
Camron Goforth
P.O. Box 394
V0B 1G0
Creston BC
CANADA
Thanks
PostPosted: Mon Oct 20, 2003 10:19 pm
Done...! Your welcome.
PostPosted: Tue Oct 21, 2003 7:14 pm
Sent it out today. I'm not sure when you might recieve it...as i'm sure it well have to pass customs....stay warm in the mean time. 8)
PostPosted: Tue Oct 21, 2003 8:07 pm
8)
Thanks buddy
