It is currently Sun Jun 07, 2026 10:11 pm
PostPosted: Fri Oct 05, 2012 7:40 pm
Ok so bought a luv and it runs great other than this problem...its a automatic and ill start it(starts fine) put it in reverse and then drive but as soon as i give it gas it dies??? It will idle fine but when i am driving if i slow down to make a turn and then accelerate out of the turn it will hesitate (sounds like its gna die)and drive fine...when this problem happens i have to keep turning the engine over and hammer down on it get it driving down the road..i have cleand the top of carb and put new gasket in even changed the accelerator pump...any info would be greatly apprieciated!!!! Would like to make it my daily driver so i can start baggin my s10!!!!
PostPosted: Fri Oct 05, 2012 8:08 pm
Can you see fuel in the window on the carb when it dies?
PostPosted: Sat Oct 06, 2012 1:51 am
Sounds like your accelerator pump is not working. Engine off, look down into the carb throat and move open the throttle linkage by hand---should see a squirt of fuel into the carb. If not remove the accelerator pump, and look into the pump well, make sure the check ball is in there. If you invert the carb with the top off during a rebuild the ball will fall out and get lost.
Happens some times.
PostPosted: Fri Oct 12, 2012 9:55 pm
My 76 LUV with an automatic did that too, I would have to warm it up really good and I think it was the choke that was causing all the problems. Does it happen only on cold starts or always?
PostPosted: Sat Oct 13, 2012 6:17 pm
Always...i dont know...im stumped but you guys think it could be crap in the fuel tank or lines???its getting fuel at carb and accelerator pumps workin as it should
PostPosted: Sat Oct 13, 2012 10:20 pm
It could be crap in the tank.It would get enough fuel at idle but die under load.I dropped my tank and cleaned it with muratic acid.Then you have to neutralize it with vinegar and water. I also use two fuel filters.One at the tank and one at the carb.
PostPosted: Sat Oct 13, 2012 11:05 pm
What would be a way to see if theres crap in the tank other than droppin it??? If possible
PostPosted: Sun Oct 14, 2012 7:52 am
Take your fuel filter out and see if the fuel that comes out of it is clean or rusty/dirty.
PostPosted: Fri Oct 19, 2012 1:18 am
My '76 Man. is doing the same darn thing right now...I have checked everything that you all have posted here and everything seems to be in working order, but still spits and spudders when taking off.
My House Is Guarded By A Shotgun 3 Days A Week. Guess Which Days.
PostPosted: Fri Oct 19, 2012 9:31 am
Come to think of it my 76 did this sometimes when it was warm too. I always blamed this on the POS Hitachi carburetor, my friend called it a "flat spot" or a "dead spot" where the carb can't get enough gas into the carb without flooding it out or something like that...
PostPosted: Fri Oct 19, 2012 11:28 am
When mine did that with the Hitachi it was float level set too low. When I fixed that it got a lot better but not 100% fixed.
Users browsing this forum: No registered users and 73 guests
