It is currently Wed Jul 01, 2026 12:04 pm
PostPosted: Mon Sep 10, 2012 6:03 pm
old clutch cable snapped in half. Ordered a new one and cannot get it to fit. With the cable adjusted all the way out from the firewall, its about 3/4" too short. I tried hooking it up at the pedal first and then to the tranny first, neither worked. Any suggestions?
PostPosted: Mon Sep 10, 2012 6:47 pm
Did the cable seat good where it goes thru the hole in the transmission?
PostPosted: Mon Sep 10, 2012 7:36 pm
you may laso check where the cable goes through the fire wall. Mine when i got it was worn a groove through the grommet.
PostPosted: Mon Sep 10, 2012 9:24 pm
Not sure I understand but---to make the internal cable longer you adjust it in to the firewall more, not out. I'm talking from the engine side.
PostPosted: Tue Sep 11, 2012 11:41 am
The cable was seated good through the hole in the transmission. I pulled the expanding rubber protector through the hole and made sure that the metal stopper on the cable was seated against the tranny. I tried adjusting it both ways at the firewall as well. It would be my luck that I get a blem cable. Its a pioneer ca413 which is pretty standard it looks like. I shouldnt have to adjust anything to put a new cable on, I wouldnt think.
