It is currently Wed Jul 01, 2026 5:58 am
PostPosted: Tue Sep 04, 2012 8:58 pm
what do i need to do with the vacume lines on the carb that run to the smog stuff ? i would like to upgrade to a weber carb if anybody has a good one layin around i cant afford to buy a new one i am still high school trying to save money for a house i am a senior this year so i dont have a disposable income to drop into my truck i have the motor out at the moment because it jumped time because the machine shop fucked me on a 1500 dolar rebuild and they didnt even replace timing gears chain or tensioner like they said they did but wont stand behind there work i am almost out of money to put into my truck and it is my daily driver so i need to get it back on the road asap so any advise on making it run better would be greatley apreciated i am not new to the site but new to having to ask for help on here but i do have 77 luv parts that i would do some swapping around on to get a webber carb to fit my truck.
File comment: this is the 77 that i have for parts
File comment: this is my beast that has officially ate me out of every dollat i had saved
if it aint a luv it aint shit
PostPosted: Wed Sep 05, 2012 3:45 pm
alright short rundown of some of the bigger things to remove.. the copper tube that runs from the exhaust manifold to the bottom of the intake manifold, it comes off, plug the hole in the exhaust with a pipe plug, the one on the intake manifold with either a plate or weld the hole shut. IT MUST be air tight, remove the air pump and the hoses attached to it,plug all the open holes from it. plug the holes that are over the exhaust manifold from the air injection rail the 4 holes with the copper tubes, plug with a 14mmx1.25 threaded plug (i made my own since the only thing i could find with the right threads is a spark plug, there should end up being a few extra vacuum ports on the base of your carb which you can plug with vacuum plugs from any part store.
there is a hose that goes from the valve cover to the base of the carb its only about 6" long and 1/4" wide leave that one there, also if your keeping the stock carb you can keep the stock air cleaner and keep using the PCV valve, which is the port on top rear of the valve cover, if you take it off it will need to be routed to a filter or charcoal canister or it will make an annoying oily smell... mine just vents to the air and i can smell it when im at a light or in traffic. also there should be a diagram of the entire emissions system on the unders ide of your hood, i used it to help me track down the emissions parts on my luv its pretty handy if your unsire of what your lookin at
PostPosted: Wed Sep 05, 2012 4:06 pm
The LUV Series 10 shop manual is what you need. Drop the cash on one and never look back. It has helpful images and diagrams which would function as visual references to love4theluv's rundown, and it explains very clearly which vacuum lines do what. It would help remove the ambiguity from the situation, so you don't end up removing something you need.
These here are more than $20, but hunt around. I think I only paid 8 bucks for mine.
http://www.amazon.com/Chevy-Series-Repa ... air+manual
PostPosted: Wed Sep 05, 2012 7:55 pm
thanks guys i already had all the smog stuff off and plugged i had another emisions rail that i cut the eds off of and welded the hole shut on the fitting so i basically made plugs py removing the copper tubes and filling the holes and i have a plug for the exhaust and intake
Users browsing this forum: Bing [Bot] and 40 guests
