im not sure whats goin on i just bored and put in new pistons rings and head gasket last year head and block was plained and put bacl togather ran fine for almost a year and busted a head gasket so i replace it and torqued to factory specs and all and once again it ran fine for bout a month now once again it is cutting out and running like shit so i took the head off today and every thing checks out good it is running a consistant 90 psi on all canylinders any ideas i messed with the distributor timing a bit and it never got any beter has a dead spot about 1/4 way into the gas pedal and it is the original 4 cylinder motor
File comment: this is it
