It is currently Tue Jun 30, 2026 3:20 pm
 Post subject: Replacement Radiator
PostPosted: Tue May 29, 2012 12:17 am
Searched around a bit, and hope this is not redundant. I have a 79, and recently replaced the engine with a re-manufactured one. My radiator is a little worse for wear, and I don't want to risk blowing up another 1.8. I'm looking to replace the radiator with another one. Any suggestions for what to buy that will install with minimal alterations? Thanks.
 Post subject: Re: Replacement Radiator
PostPosted: Tue May 29, 2012 1:43 am
http://www.ebay.com/itm/JEGS-Performanc ... ce&vxp=mtr
64-66 Mustang radiators were the closest I've been able to find. I have one, but it's not yet installed. My radiator is fine as long as I keep it under 55 :lol:
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Tue May 29, 2012 5:48 pm
Thanks I have the same issue with mine. Runs nice and cool until I go over 55mph
PostPosted: Wed May 30, 2012 11:53 am
Any one else have any ideas? Just want to have options. Maybe some pointers from someone that's done the swap?
PostPosted: Wed May 30, 2012 9:11 pm
Why don't you just take your radiator to a radiator shop and get it recored? It will be cheaper than getting a new one and if you have a reputable shop do it they can put more cooling capacity in it. Aldo have you guys hears of a thing called a flex fan? Or have you tried an electric cooling fan? These things will help keep your little truck cooler and frees up what little horsepower we can get!
PostPosted: Thu May 31, 2012 12:51 pm
I'm the first to admit I'm not the most mechanically inclined. Can do simple repairs starter, water pump etc. Could you please elaborate on the Flex Fan and a little about the process to install an electric fan?
PostPosted: Tue Aug 14, 2012 11:11 pm
i got one for a 80's toyota pickup and it fits just fine, its a lil big but not enough to cause any issues and it has no problems cooling at any speed. also put in a electric fan from a subaru
Users browsing this forum: Baidu [Spider] and 44 guests
