It is currently Sun Jun 07, 2026 7:47 pm
 Post subject: Starting Issues
PostPosted: Wed Jun 06, 2012 7:23 pm
So the truck was running a little rough (79 1.8L stock) so I decided to adjust the carb in accordance with the Haynes manual. I did everything that it said and the truck was idling perfect. Let it run while I wiped down some dirt and what not in the engine bay and then turned it off. Then it wouldn't start back up... So I decided to up the idle a whole bunch with the screw and it started and idled very very high so I backed it off and performed the adjustment settings again, but the way the instructions on the hood said. Ran perfectly drove it for a while and shut it off... I thought I wonder if it would start, and it did not... Any ideas? I don't know a whole lot about carbs but it blows my mind that it started just fine and now its being a punk. Thanks guys!
 Post subject: Re: Starting Issues
PostPosted: Wed Jun 06, 2012 7:26 pm
I was also wondering if there was any way to tell which Hitachi I have exactly
PostPosted: Thu Jun 07, 2012 11:39 am
ok new developement... The truck starts when it is cold but once the truck warms up to normal temp and I turn it off it will not start until it is cold... Like I say it runs so smooth so it blows my mind
PostPosted: Fri Jun 08, 2012 8:19 pm
Adjust your air fuel mixture screw
[color=#0000BF]luv truck 06.04.2011.[/color]
