It is currently Wed Feb 18, 2026 10:19 pm
 Post subject: i need a windshield seal
PostPosted: Wed Mar 21, 2012 2:07 pm
im getting a pretty bad leak down under my glove box so i think i need to track down a new window seal
going to have to seal around the panel up front before i yank out the windshield to be sure its not coming from up there. but it looks like its dripping down from the windshield.... passenger side floor is soaked in the morning after it rains... which in washington is at least 3-4 days a week :roll: fear of rust retting biblical :evil:
PostPosted: Thu Mar 22, 2012 5:23 pm
Luvs are famous for leaking through the plenum. Take the grill under the wiper arms off and see if there is any sign of a leak there.
Also replace the rubber sleeve over the base of the wipers with spark plug boots.
PostPosted: Thu Mar 22, 2012 5:32 pm
A new windsheild seal is obtainable . They just destroyed the windsheild and seal pulling mine for a cage . New glass with seal for stainless trim installed $240 .
PostPosted: Thu Mar 22, 2012 6:26 pm
My local glass shop sold me mine.
PostPosted: Thu Mar 22, 2012 6:59 pm
Seems to me, it would be many other things before the window seal. Like mentioned, the wiper posts, radio antena hole, the holes in the cab that hold the wiper cowl or rust holes in the rocker panels or fenderwells (unless it is leaking when you are not driving it).
PostPosted: Thu Mar 22, 2012 7:49 pm
im going to go thru and put some rtv under the antenna hole and seal up around under the grill piece tomorrow afternoon before work and see if that fixes it. it snowed last night and the floorboard was completely waterlogged.. starting to get some rust under the carpet so its time to get this taken care of asap
and tilted it leaks moving or not. i can come out in the morning after a good rain and see the floor completely soaked when it was dry before. thinking its probably the grill in front of the windshield
PostPosted: Thu Mar 22, 2012 10:18 pm
My guess is the wiper arms. Like said before, get some sparkplug boots to seal it. Here is a good write up to follow from 800XL.
viewtopic.php?f=5&t=849&p=5135&hilit=spark+plug+boot+wiper#p5135
PostPosted: Thu Mar 22, 2012 11:10 pm
thanks that will help a lot, it would make sense that it may be the wiper shaft i have noticed one of them has been making a squeak lately so it is probably worn bad enough to be leaking :egeek
PostPosted: Sat Mar 24, 2012 4:28 pm
I had my windshield replaced last year. The glass shop could not find a seal for the stainless trim (hotrod80 if you could find out where the glass shop found yours could you let us know). I replaced the wiper posts with spark plug boots and still have water leaking after a good rain, but not as much as before replacing the wiper boots. I would like to put in carpet but not until I locate the leak.
76 LUV
PostPosted: Sat Mar 24, 2012 6:22 pm
I will monday . He gave me a 3 letter name for a wholeseller , but i dont remember it . Nice truck by the way
PostPosted: Thu Mar 29, 2012 4:51 am
He told me he had to order it from the precision factory and this one is without the trim which i have and am not happy about giving up . Im thinking this is the place .
http://www.prp.com/
Users browsing this forum: Bing [Bot], Google [Bot] and 36 guests
