It is currently Sun Jun 07, 2026 7:12 pm
 Post subject: 1.8 head on 1.9 G200?
PostPosted: Mon Jan 30, 2012 11:06 pm
Iv heard that the 1.8 head will fit in the 1.9L and u can boost compression resulting in more torque and power
So I asked a mechanic I know to help me put new pistins rings and a 1.8 head in my G200 and he said no he knows from expierence it can screw it up... Has anybody on here done this and had a problem.
PostPosted: Thu Feb 02, 2012 4:04 am
as far as i have heard it works pretty well actually...
go to ozgemini.com and browse the forums they are the g series experts
PostPosted: Fri Feb 03, 2012 3:15 am
Will do thanx fellow washitonian
PostPosted: Fri Feb 03, 2012 10:18 pm
your welcome
the recommendation for the heads i have heard is use the 1.8 head, smaller chamber for higher comp, with the 1.9 valves for better flow and a cam regrind will wake the motor up a lot... weber carb, 85 isuzu pup electronic distributor, and pacesetter headers and such upgrades will give you more gains.
i used to live up on beacon hill in Longview, kind of miss it up there Vancouver isn't much but a suburb of Portland anymore.
PostPosted: Tue Feb 07, 2012 8:28 pm
Yea sweet iv allready got the webber so that should work out great
Longview is one of a kind :) ...I grew up on coal creek...
PostPosted: Tue Feb 07, 2012 9:48 pm
one of a kind is a great way to describe it :lol:
make sure you get a good head gasket if you dont plan to pull the head again soon afterward.
let us know how it goes. not enough people build the 1.8's... i started to but decided i need a few more cubes :lol: the 85 pup distributor helps quite a bit, 2 wire electronic hookup and it gives you a seat of the pants power upgrade for sure. rockauto has them for pretty cheap (80-90 bucks)
PostPosted: Thu Mar 29, 2012 6:09 pm
Thanx ..I love rockauto..
Will do, considering my dizzy may be a prob right now .......I'm misfiring bad
PostPosted: Sat Mar 31, 2012 8:21 pm
Make sure the head is straight! Take it to a machinist and have him check it with a straight edge!
