It is currently Sun Jun 07, 2026 2:25 pm
 Post subject: A friendly reminder
PostPosted: Thu Jan 26, 2012 1:15 am
Woo! Got my truck started again after not having any time to work with it much, I finally got to use my xmas gifts, a dwell meter, and a compression tester. ^_^
Got right around 125 compression on all 4 cylinders, my spark plug gap was a little wide(I'm gonna buy a new gap meter stick thingy...) and my points were all but touching from the carbon build up, so I gaped that out to where it should be, and got some new ones from the autoparts store. so once again I have been foiled by points, let this be a friendly reminder to all of us... God damn points. :)
 Post subject: Re: A friendly reminder
PostPosted: Sat Jan 28, 2012 4:05 am
and this is why i finally chucked that dizzy and got an 85 pup electronic one
PostPosted: Sun Jan 29, 2012 10:08 pm
So an 85 pup will work in a 77 luv eh? Is that an easy swap, vaccuum tubes etc? Are there other options I can consider... aside from carrying a feeler gauge and dwell meter in the bed? :)
PostPosted: Sun Jan 29, 2012 10:35 pm
This works for me: http://www.pertronix.com/prod/ig/ignitor/default.aspx
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Mon Jan 30, 2012 8:07 am
What is the part number of the Pertronix you are using.
76 LUV
PostPosted: Mon Jan 30, 2012 10:21 am
Part no. 1643 for my '78
I ordered it here: http://www.vintageperformance.com/retro ... evrole.htm
PostPosted: Tue Jan 31, 2012 1:36 am
I got a distributor out of a pup at a pick and pull for $30. It works great.
1980 LUV 2wd - More pounds in rust than torque
1994 Jeep Cherokee 4x4 - Lifted with lights ;)
PostPosted: Sat Feb 04, 2012 7:29 pm
no finagglin needed? no vacuum hose adjustments? just swap'n'go?
someone post me a picture :)
PostPosted: Fri Feb 10, 2012 8:19 am
Haruspex, were there any other parts you had to order, or was everything in the kit.
76 LUV
PostPosted: Fri Feb 10, 2012 10:59 pm
please do tell
PostPosted: Sun Feb 12, 2012 1:10 am
to swap to the electronic pup dizzy you literally pull theold one out, hook the vac advance up same way as the old one.. one wire to (+) and one to (-) on the coil.. set the timing and your good to go. the conversion took me less than an hour
PostPosted: Wed Feb 15, 2012 3:16 am
why did it take you so long did you misplace your bottle opener? :lol: :lol: :lol:
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
PostPosted: Wed Feb 15, 2012 10:12 am
Everything was there. Took a grand total of 10 minutes to install.
PostPosted: Wed Feb 15, 2012 12:06 pm
had to partake in some festivities half way thru :lol: :lol: and then again after i fired it up
PostPosted: Mon Mar 05, 2012 9:33 pm
New Points on, woulda' been sooner but i needed gas for the swap... and at $4.04 gal... well...
gonna ride these puppies till they poop on me, then I may decide to swap electronic or not, I've almost got these points thingamajigs down! :D
Thanks to everyone for the links and ideas!
