It is currently Sun Jun 07, 2026 10:41 pm
 Post subject: Heater core
PostPosted: Sat Feb 04, 2012 4:25 pm
How easy is it to change the heater core?
 Post subject: Re: Heater core
PostPosted: Sat Feb 04, 2012 4:57 pm
Depends on your level of expertise.
PostPosted: Sat Feb 04, 2012 9:17 pm
And it might depend on what your vehicle is.
PostPosted: Sat Feb 04, 2012 11:03 pm
I'm sorry. I'm a newb. Is it difficult to change the heater blower motor on an 80 luv? and where is it located?
PostPosted: Sun Feb 05, 2012 12:34 am
In my opinion, it would be difficult and time consuming for a newb, but not impossible.
To over simplify:
  • With the engine cool, remove the heater hoses from the heater core in the engine compartment and let them drain into a pan.
  • In the cab, remove the shelf on the passenger side under the dash, if you have one.
  • Remove the climate controls assembly and disconnect any cables needed so you can swing it to left side and lay it on the floor.
  • Remove the entire heater case as one unit to the right and down. It will take some effort to get the heater tubes out of the firewall.
  • Once you have the heater case out, split the unit in half to get to the heater core.
  • Replace the core, and reverse the process to reassemble. Make sure all the little cables for the climate control go back where they came from.
Users browsing this forum: Baidu [Spider] and 28 guests
