It is currently Sun Jun 07, 2026 8:21 pm
 Post subject: Relay? Help
PostPosted: Sat Jan 07, 2012 9:46 pm
My 77 luv im going with ls1. Started wiertuck but the 2 relays on passenger side by washing fuild what r they?
 Post subject: Re: Relay? Help
PostPosted: Sat Jan 07, 2012 11:01 pm
Not being an azz, not sure what you are trying to do...
PostPosted: Sun Jan 08, 2012 1:09 am
I started a wiring tuck . But i dont no what the 2 relays by the windshield washing fluid under shroud r
PostPosted: Sun Jan 08, 2012 2:41 pm
Fuel pump and resistor bypass relays. You should find a wiring diagram if you don't have one already.
PostPosted: Sun Jan 08, 2012 7:03 pm
One is a double throw relay for the fuel pump. The fuel pump is hot in start and needs voltage from the voltage regulator in run. I think the other provides a direct battery to coil connection in start.
PostPosted: Wed Jan 11, 2012 2:50 pm
I cant find a diagram that tells me color
PostPosted: Thu Jan 12, 2012 10:11 am
Search "fuel pump relay diagram". Labman helped me out a bunch there. Listed is the colors of the wires and where they go. Good luck.
1974 Mikado 4x4 50,000 orig. miles
