It is currently Sun Jun 07, 2026 11:48 pm
 Post subject: Diesel selnoid
PostPosted: Mon Jan 09, 2012 9:44 pm
I did some testing tonight on the anti diesel selnoid and found that I have 11 volts in the pigtail for choke and anti diesel selenoid however truck will not idle but when I switch wires choke will not work but selenoid will work..any ideas. Or if I run a seperate wire from battery to anti diesel truck will idle ok. Something is going on with the factory wire for anti diesel but it measures ok for voltage...and ideas
 Post subject: Re: Diesel selnoid
PostPosted: Tue Jan 10, 2012 6:28 pm
Bad connection somewhere. It can show voltage there with the connector loose and measuring with a meter but with it connected up to the load it will fall off. Measure it with it connected to its load. Both wires are supplied from the ignition switch.
