It is currently Sun Jun 07, 2026 7:49 pm
PostPosted: Fri Nov 25, 2011 4:21 pm
I'm thinking about switching to dot 5 (silicone) break fluid when I do my master cylinder. Ive goggled around and found out some information, but I am hoping for advice from some one that has done this to a luv.
PostPosted: Fri Nov 25, 2011 5:13 pm
Completely flush your old fluid out. Remove the lines from all 4 corners and push it through, then bleed it several times to be sure it is flushed out. Then you will be fine...
PostPosted: Fri Nov 25, 2011 8:21 pm
I swapped to Vavoline 3 & 4 synthetic . Works great .
PostPosted: Sat Dec 03, 2011 11:59 am
DOT 5 has to have wheel cylinder and caliper rubber made out of special material or it will swell up and eat the rubber!
PostPosted: Sun Dec 18, 2011 12:09 pm
Already done, no problems so far.
PostPosted: Sun Dec 18, 2011 5:57 pm
The vavoline 3 4 syn. Is compatible with 3 seals and will mix . It is only about $2 more a jug .
Users browsing this forum: Baidu [Spider] and 50 guests
