It is currently Sun Jun 07, 2026 8:16 pm
 Post subject: Dim dash lights
PostPosted: Mon Feb 13, 2012 2:15 pm
My dash lights are barely visible. I’ve replaced the bulbs (no help). Has anyone come across this issue? If so, how did you fix the problem?
76 LUV
 Post subject: Re: Dim dash lights
PostPosted: Mon Feb 13, 2012 4:35 pm
I assume you tried to adjust the dash light brightness via the headlight switch? Turn it left or right to adjust.
PostPosted: Mon Feb 13, 2012 6:53 pm
If not the switch could be bad connections somewhere. No sense trying to do much on an electrical problem until you have done the fuse box. The terminals the wires connect are riveted to the fuse holders. A little age and corrosion, and you get electrical intermittents. I solved mine by taking it apart and soldering the joints. Others have cleaned it with lemon juice, and others a new fuse box.
PostPosted: Mon Feb 13, 2012 9:38 pm
Light switch on full bright. Fuse box rebuilt and cleaned.
76 LUV
PostPosted: Mon Feb 13, 2012 11:42 pm
check for bad ground. that is also very common for luvs
LIVE HARD PLAY HARDER
PostPosted: Tue Feb 14, 2012 12:16 am
Does the knob vary the brightness or have any effect at all? This control does get dirty and gets intermitent and inop sometimes. You clean it with electrical contact spray just like a dirty radio volume control.
PostPosted: Tue Feb 14, 2012 8:20 am
The light switch does vary the brightness. I'll remove the switch and give it a good cleaning.
76 LUV
PostPosted: Tue Feb 14, 2012 11:40 am
You could see what voltage you are getting to the dash light circuit. That would help you determine if it's the dimmer.
Users browsing this forum: Baidu [Spider] and 43 guests
