It is currently Tue Apr 23, 2024 8:29 pm
PostPosted: Mon Sep 09, 2002 10:14 am
what water pump, radiator and fans did u guys use to put a v8 in a luv...having problems now....is it possible to run a flex fan and electric fan...and do i need a remote mounted oil filter?...what kinda hp will the stock rearend hold and is any firewall mods needed if u run a points style dist...
PostPosted: Mon Sep 09, 2002 7:03 pm
Look in "Drivetrain upgrades". Topic "Radiator suggestions on V-8 Conversions". Ben has put together some useful info you might what to look at.
PostPosted: Mon Sep 09, 2002 10:21 pm
i ran a 350ci with a 100shot of nos on the stock rear end the motor made
about 250hp the rear held up good!. i changed to a 9" now .i run a ron griffin radiator 19"x22" and a stock shortty water pump { off a truck
or a corvette}and it works great !
PostPosted: Wed Sep 11, 2002 1:15 am
I know there's a little info about this in some past posts. I would try the bulletin board "search" function (under "User Options") first and see if that helps. If you need more info then we'll go from there.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Tue Sep 24, 2002 4:57 pm
Kind of a late repy, but I've had three different sizes in and all fall short of cooling. On a hot day, :oops: mine still spits a bit. Go ALUMINUM and dont waste time on anything else, if you can.
