It is currently Fri Jun 26, 2026 10:41 am
PostPosted: Mon Sep 09, 2002 10:14 am
what water pump, radiator and fans did u guys use to put a v8 in a luv...having problems now....is it possible to run a flex fan and electric fan...and do i need a remote mounted oil filter?...what kinda hp will the stock rearend hold and is any firewall mods needed if u run a points style dist...
PostPosted: Mon Sep 09, 2002 7:03 pm
Look in "Drivetrain upgrades". Topic "Radiator suggestions on V-8 Conversions". Ben has put together some useful info you might what to look at.
PostPosted: Mon Sep 09, 2002 10:21 pm
i ran a 350ci with a 100shot of nos on the stock rear end the motor made
about 250hp the rear held up good!. i changed to a 9" now .i run a ron griffin radiator 19"x22" and a stock shortty water pump { off a truck
or a corvette}and it works great !
PostPosted: Wed Sep 11, 2002 1:15 am
I know there's a little info about this in some past posts. I would try the bulletin board "search" function (under "User Options") first and see if that helps. If you need more info then we'll go from there.
PostPosted: Tue Sep 24, 2002 4:57 pm
Kind of a late repy, but I've had three different sizes in and all fall short of cooling. On a hot day, :oops: mine still spits a bit. Go ALUMINUM and dont waste time on anything else, if you can.
