It is currently Sun Jun 07, 2026 8:14 pm
PostPosted: Tue Aug 30, 2011 1:52 pm
ohms meter showing black and white wires as connected
is this a short?
and showed 3.55 vdc resister to coil
black is ground
blue hot
what are white/black
and yellow/black?
i have the wiring diagram arent sure what those wires go to/i know someones replaced thiers out there, what part id number did you use and what #'s on the ports did each wire go to?
solves a headache if ours isnt working just to replace it
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
PostPosted: Tue Aug 30, 2011 2:20 pm
Black/yellow is ignition. Black/white is start. In start, power flows from the start to the NCC terminal to the fuel pump on the one relay. Iguess you are working on the other.
