 Post subject: fuel tank relief valve
PostPosted: Mon Sep 22, 2003 12:43 pm
Would anybody happen to know if there is a fuel tank relief valve on a chevy luv and if there is where would it be
PostPosted: Tue Sep 23, 2003 5:05 am
well I haven't taken any of our tanks off and looked at something wondering "what the hell is this"
so I guess not.....
I could be wrong though, so lets wait for someone else to chime in.
03Cobra
PostPosted: Tue Sep 23, 2003 8:13 am
I removed the fuel tank and lines from my 80 , and i didnt find anything like that. Shane are you still haveing trouble keeping your truck running?
PostPosted: Tue Sep 23, 2003 8:22 am
Yah it still wont run right, I've given up for the past two weeks
PostPosted: Tue Sep 23, 2003 12:18 pm
Yes, there's a pressure relief valve under the hood. It's on the firewall and it has 3 vacuum lines comming off of it . One line is for clean air, one runs back to the tank, and the 3rd line goes to the oil pan. The system is designed to keep a little pressure in the tank. Thats why when you remove the gas cap, you can feel the pressure escape. Any excess pressure that may build up in the system will be vented to to oil pan so the engines PCV system will burn off the fumes. As excess pressure builds up too high, you can hear it being vented by a buzzing, rattleing noise from the valve under the hood. This system is for emissions control and i've havent heard of any going bad. The extra pressure helps out the fuel pump slightly but it isn't mandatory to run the truck. If you have the clean air line hooked up to a wrong port, it could create a vacuum condition and create a vacuum condition in the tank and cause fuel starvation.
