It is currently Sun Jun 07, 2026 9:32 pm
PostPosted: Tue Aug 30, 2011 1:52 pm
ohms meter showing black and white wires as connected
is this a short?
and showed 3.55 vdc resister to coil
black is ground
blue hot
what are white/black
and yellow/black?
i have the wiring diagram arent sure what those wires go to/i know someones replaced thiers out there, what part id number did you use and what #'s on the ports did each wire go to?
solves a headache if ours isnt working just to replace it
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
PostPosted: Tue Aug 30, 2011 2:20 pm
Black/yellow is ignition. Black/white is start. In start, power flows from the start to the NCC terminal to the fuel pump on the one relay. Iguess you are working on the other.
Users browsing this forum: Bing [Bot] and 36 guests
