It is currently Sun Jun 07, 2026 7:13 pm
PostPosted: Sun Aug 14, 2011 2:27 pm
thinking about getting a weber carb whenever i can get the funds, not as soon as i hope :( i saw this one
http://www.jtspeed.com/product_info.php ... s_id=23876
not saying i would get it from this site but would this be a good one thats compatable with my 1980 chevy luv 4x4 1.8L stock engine? I am in california and the site said to check if its legal in california to use. anyone know?
What part is this?
What is it for?
How Do I test it?
Where do i get a new one?
Are we there yet??
PostPosted: Sun Aug 14, 2011 4:11 pm
looks just like my weber :)
i have the 32/36 electric choke etc. runs great on my luv. not sure if u can get them legal in california since it is technically an "offroad/performance carb"
call the local smog testing center to find out before you buy
PostPosted: Sun Aug 14, 2011 7:45 pm
ok thanks i dont offroad i still have the stock carb and its a mess worn out. need to replace it along with a valve cover gasket thats leaking on the manifold ARGH . people are suggesting a weber. i just need this ting to be able to pass smog. havent tried to yet but it has squeaked by the last 2 smogs.
What part is this?
What is it for?
How Do I test it?
Are we there yet??
PostPosted: Sun Aug 14, 2011 9:46 pm
weber wont pass in california.
1974 Chevy LUV 4x4 Weberfied
PostPosted: Sun Aug 14, 2011 10:44 pm
ok thanks
regarding vacuum motors -we tested with a vacuum pressure gauge. with it hooked up it reads 0 if we unhook it and test, the vacuum meter read 14 inches steady on idle.
i understand it is called a vacuum motor however there are no images of one to google and no parts called that. could it be called by any other names? i am in california and it would be required for ca. standard emissions. its hard to believe its not an available part unless i am searching the wrong term (chevy luv vacuum motor) the diaphragm inside the unit must be faulty as vacuume leaks right through it.
What part is this?
What is it for?
How Do I test it?
Are we there yet??
Users browsing this forum: Bing [Bot] and 41 guests
