It is currently Sat Jun 27, 2026 10:57 pm
PostPosted: Sat Sep 07, 2002 12:05 pm
OG Lifer
ive been hearin 'bout people swappin' the old nasty carbs for one of them new fangled webbers. any need to change minor stuff or major? does it no longer need the anti-dieseling solenoid or any of that other crap? my carb is mostly covered up with electic devises and im not sure if i have to try to jump wires across these components to cancel them out of the system or not. someone help cause i dont wanna buy another hitatchi if i can get a webb. thanx :)
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sat Sep 07, 2002 2:43 pm
Years ago with my stock motor i ran a 32/36 DGV Webber. It was a good running carb. The only emmisions i had was the pcv. Everything was removed or capped. I also replaced the adapter plate for the stock intake with a 2" riser adapter because the thin adapter plate had a problem. The secondary would restrict when at full throttle( anyone with a DGV carb knows what im talking about)By all means, install a webber. Scrap the emmisions jazz. You'll lose gas milage because of emmisions loss and the fact that your always putting your foot to the floor just to hear the secondary open. Just make sure your top end gaskets dont leak.
PostPosted: Sat Sep 07, 2002 3:31 pm
OG Lifer
well thank ya for the info. i will find a webber to replace the craptachi and i dont care about the gas miliage :D thanx again
PostPosted: Sat Sep 07, 2002 10:23 pm
Also you might consider modifing your exhaust system if you haven't already. You'll be able to use the new carbs full potential.
PostPosted: Sun Sep 08, 2002 11:32 am
OG Lifer
yeah i already have a header and bigger pipe. but the muff could use a flowmaster or something. i need all the power i can get for when i get my new a/c compressor :wink: not alot of power to pull the truck and the a/c!
Users browsing this forum: Baidu [Spider] and 72 guests
