It is currently Sun Jun 07, 2026 7:32 pm
 Post subject: 1981 Luv Stromberg Carb
PostPosted: Fri Jul 29, 2011 12:21 pm
I have had my 4wd Luv for 3 years and have only had it idleing. i believe the carb has sucked some crud out of the tank. i can only find a parts breakdown in a service manual from the 80s. i can not, however, find a carb kit. i was wondering where to go for this kit or where to find more info about this carb. thanks for any help.
Dustan
As clear as a mud puddle!!
PostPosted: Fri Jul 29, 2011 6:42 pm
Probably because it is a Mikuni carb.Go to the newbie section and look...you will probably find it!
PostPosted: Thu Aug 04, 2011 12:49 pm
got one found! i have a carb guy workin on it now. i figure i will put an inline filter in to strain the bulk of the crud out! thanks a lot!
PostPosted: Fri Aug 05, 2011 6:34 am
There is a in line filter by the fuel tank on top of the frame rail already that is stock. Well it should be there and is one of the 2" round with 5/16" in/out.
