It is currently Mon Jun 08, 2026 2:07 am
PostPosted: Thu May 19, 2011 8:19 am
i just ordered my carb, the 32/36 orr weber website, anyway, the fuel pump i have is electric and pushing 2.5 to 4 psi is that ok for the weber? also is everything in the kit that i need to get it going or am i goin g to need additional stuff?
PostPosted: Mon May 23, 2011 8:43 am
I am running just over two psi fuel pressure on my Weber and it runs fine. Just be sure not to go too high or you will have problems as I found out. Don't know what comes with the carb kit you purchased but you will need an adapter plate to fit the carb to the existing stock intake. Need more information and the year of your truck with any engine changes you may have.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue May 24, 2011 7:02 am
i have a 74 chevy luv 2wd 4-speed, i bought the carb kit with the adaptor plates supposed to come with everything needed to put it together. i just got it in the mail yesturday, havent put it on yet
PostPosted: Wed May 25, 2011 12:40 pm
i got the carb put on, it runs 100% better then it did, now just need to upgrade dist. anyone done this??? is it worth it?? what is the best kit to do it, 74 luv 2wd 4-speed
PostPosted: Wed May 25, 2011 1:01 pm
trooper electric dizzy 83-86? i hear works great not sure if it will fit your early style engine though.
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
