It is currently Wed May 27, 2026 6:17 am
PostPosted: Mon Apr 04, 2011 1:31 pm
I just put a new weber carb on my luv and it done wonders for the starting and idling and even the driving but when i got it on i took it for a test drive down the road and i only made it about a quarter of a mile and it just died. I could get it to start and run for about 10 sec and it would die again. I'm thinking somthing is getting hot and shutting it down because i can let it sit for alittle while and cool off and it will start and run again. If anyone has any ideas please let me know. Thanks
PostPosted: Mon Apr 04, 2011 1:38 pm
Fuel pump and or relay??????
PostPosted: Mon Apr 04, 2011 1:42 pm
Im not sure it could be the fuel pump because its new and it runs great for a little bit. I didnt think of the relay, ill check them and see. thanks
PostPosted: Mon Apr 04, 2011 1:52 pm
One more question, would the vapor canister have anything to do with it not running because mines not hooked up.
PostPosted: Mon Apr 04, 2011 2:04 pm
how was the truck running befor you changed the carb?
when was the last time you changed your fuel filter?
I will no longer do that thing with my tongue
PostPosted: Mon Apr 04, 2011 2:11 pm
the truck ran like crap before i changed the carb. I couldnt even keep it idling without turning the idle way up. I change the fuel filter at least every other week if not sooner and i also have 2 fuel filters on it. The one by the tank and then i added one by the carb just to make sure nothing got to the carb.
PostPosted: Mon Apr 04, 2011 6:08 pm
Mine did something similar when the needle and seat was stuck in the float bowl of the carb.
PostPosted: Tue Apr 05, 2011 3:01 am
I had a combination of problems here is a link to the thread, hope this helps-
viewtopic.php?f=5&t=22771
PostPosted: Tue Apr 05, 2011 4:47 am
Could be a dying coil too.
PostPosted: Tue Apr 05, 2011 2:40 pm
I had a similar problem with my 81 after a Weber install.
I found that the tank was not venting right due to the unused return line and canister my dad solved it for the most part by drilling a small 3mm hole in the gas cap.
Do not know why but it seamed to fix the problem for me.
G
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Wed Apr 06, 2011 3:56 pm
Thanks guys. Ill try some of that stuff out in the next few days and get back and see if it helped.
Users browsing this forum: Bing [Bot] and 56 guests
