It is currently Wed Jun 10, 2026 2:56 am
 Post subject: crankshaft interchange
PostPosted: Mon Mar 28, 2011 6:27 pm
Basic question here. Is the crankshaft from the early 73, 74, 75 non-crossflow head 1.8l engine, interchangeable with the 1976 and later crossflow head 1.8l engine. I need to replace my 74 crank and they are not available in my area. However, 76 and later cranks are quite common. Thanks for the input, dan...
PostPosted: Mon Mar 28, 2011 9:25 pm
My parts book says no.
PostPosted: Sat Apr 02, 2011 10:49 am
You can send your old crank to a machine shop that does crank welding to build a bad main or rod jopurnal back into spec.
PostPosted: Fri Apr 08, 2011 4:07 pm
Believe it or not, the last owner replaced the clutch and used standard thread bolts instead of metric and cross threaded all the crank/flywheel bolt holes. They fired it up and wondered how it seemed to have developed a rod knock. I tore it down and found all the crank/flywheel bolts finger loose. The crank threads did not clean up well. .dan...
PostPosted: Fri Apr 08, 2011 4:43 pm
8O
bore to the next size and re-tap? thats about all i can think of
