It is currently Wed May 27, 2026 1:11 pm
 Post subject: Headlight problems
PostPosted: Thu Feb 24, 2011 1:36 pm
It seems that I have a short in my headlight circuit.I thought it was the bulb so I replaced both on the low beam.Drivers still doesn't work.I will tear apart the connector and clean the contacts but I was wondering if anyone knows if there are still headlight switches available?Napa and another local parts store did not have them available anymore.
Any ideas?
 Post subject: Re: Headlight problems
PostPosted: Thu Feb 24, 2011 2:14 pm
Im having some of the same issues. I swapped from teh singles to the doubles. Now The Passenger is really dim and when the lights are on the right blinker only comes on and no blink unless if move little stick reall fast! Think it might be ground somewhere theats where i would start. Not on my high priority list though :ebiggrin
PostPosted: Sat Feb 26, 2011 12:18 pm
OK I have the high beams on and the drivers outer works but not the inner.I have side marker lights on both sides so it is not a ground problem.Any ideas?
PostPosted: Sat Feb 26, 2011 2:29 pm
Try swapping bulbs from side to side to be sure the new one isn't bad. Wouldn't be the first time...
PostPosted: Mon Feb 28, 2011 2:00 pm
I did that first! I also found out I have a tailight out too! GRRRRR
PostPosted: Tue Mar 29, 2011 12:31 pm
Well it was a bad fuse.I finally checked continuity on the fuses and found it.Must have been burnt next to the cap.
Users browsing this forum: Baidu [Spider] and 51 guests
