It is currently Mon Jun 08, 2026 12:18 am
 Post subject: 85 astro van engine
PostPosted: Wed Oct 10, 2012 12:56 pm
hi my friend has a astro van he wants 200 dollars for the van just the only problem its the transmission but the engine is rebuilt can that engine fit in my 77 luv is a good deal? please advise me thanks :ebiggrin :ebiggrin :ebiggrin
 Post subject: Re: 85 astro van engine
PostPosted: Wed Oct 10, 2012 1:44 pm
That V6 won't bolt to your trans. You will need the Astro trans. or something else. The V6 will fit in the truck. You will need all the electronics for that eng. and will need to make motor mounts.
PostPosted: Wed Oct 10, 2012 2:18 pm
If it's the 4.3 engine, it's not an incredibly hard swap, but as rondog said, the transmission doesn't match. www.powerbyace.com makes bolt-in mounts for the 4.3 and most popular automatic transmissions. There's more to it than just pulling an engine and putting another in. You'll need a better radiator, you'll probably want a rear end with lower gears, etc...
If you have a good running truck, I'd make sure I had EVERYTHING I needed before I started. Once these swaps get started, it's incredibly frustrating to see your truck sit for a long time without driving it.
PostPosted: Wed Oct 10, 2012 2:19 pm
And you're in California. Don't forget about smog.
PostPosted: Fri Oct 12, 2012 4:02 pm
thanks guys :D how much money i will spend for sure before to start and i'm in california :egeek
PostPosted: Fri Oct 12, 2012 8:54 pm
I would not modify a LUV in California unless it's a 75 or older. Smog laws kill us, this is why I have a 74.
PostPosted: Mon Oct 15, 2012 2:31 pm
:esurprised :? :? :? :? :( thanks anyways guys
