It is currently Sun Jun 07, 2026 7:18 pm
PostPosted: Thu Mar 10, 2011 12:55 am
[color=#FF0040]I HAVE A 1980 MICKADO FACTORY 4X4 TOOK ALL PARTS OUT OF 76 LUV WHICK CONSISTED OF A DANA 30 WHICH IS THE SAME EXACT AS A JEEP CJ7 A SPICER 18 FACTORY DIVORCED UNIT AND SPRING OVER REAR AXLE AND ALL DRIVE LINES DID THE SWAP IN 98 DID A SPRING OVER IN 2007 AND A TROOPER POWERSTEERING AT THE SAME TIME DID NOT CUT A THING USED TROOPER SHAFT SHORTENED LUV SHAFT EVERY THING WORKS PERFECT DRIVES AUSOME STILL PREPARING FOR BUICK V6 AND S10 5 SPEED THIS SOMMER HAVE MOTOR AND TRANNY
PostPosted: Fri Mar 11, 2011 9:18 pm
HECK YEAH MAN WHERE ARE THE PICS!!!
that sounds like an awesome setup. isnt the diff on a dana 30 on the driver side?
PostPosted: Fri Mar 11, 2011 9:47 pm
Why are you yelling at us?
PostPosted: Fri Mar 11, 2011 9:49 pm
no idea. sounded like fun.
:roll:
PostPosted: Tue Mar 15, 2011 8:57 pm
just as soon as i get camera back from repair there will be pics o and now it has a hood scoop autozone stile
PostPosted: Wed Mar 16, 2011 8:56 pm
WHAT IS THE EASIEST WAY TO POST PICS U GUYS WILL LIKE IT IT BUILT FOR SNOW
PostPosted: Wed Mar 16, 2011 11:16 pm
If they are loaded into your computer, you can up load them onto the site directly. Otherwise, Photobucket works well.
PostPosted: Fri Mar 25, 2011 2:41 am
I Can not get them loaded bout ready to give up i just want my pics up
